Upper rear strut brace
so i saw one of these on a GT in norwich the other week that looked sick, anyone know where i can get hold of one? does it make much difference? and also can you attach your harnesses to it? apparently you can but not to sure how safe they are? cheers rozzer :)
  • Replies 9
  • Views 1.3k
That one bolts between the turrets, which is actually better because it wont damage the threads on the struts, and is allowing the suspension to flex in it's rubbers whilst reducing the flex of the shell
o right 1st time I've seen ones like that
seems better now you explained it cheers :thumbsup:
It's ok as a strut brace but I wouldn't fasten harnesses to it its far too flimsy.
Matt
^ True, you're best off with a welded in brace to attach your harnesses to
Matt
yeah think I'm gona put them onto the rear seatbelt points, seams to be the general consensus about this type of thing :)
I don't like doing that they end up either at completely the wrong angle or with funny twists in them. As mentioned best way is to get some thick plates welded into the the rear inner arches/turrets and weld a bar across.
Matt
