Mk3 Polo
Hi thereiv bought a bready but when i switch the heater on only number 3 works not one or two and its chucking out cold air does anyone know the problem.
  • Views 924
The speed problem is your reostat (heater resistor pack), and the cold air could be a number of things but most probably a thermostat thats stuck open.
Mk3's only blow cold out of the heater vents the only place they blow warm is on you are feet and the windscreen :)
The resistor is mounted on the side of the fan, under the plastic scuttle panel under the bonnet. You can pick them up from breakers/scrap yards (worth checking with a multi meter), or buy a new one which cost £20 or more iirc.
You say it is blowing out cold air, in all positions? As the dash vents at either end are only fresh air vents, which means you only get heat to the screen and floor. It could be an air lock in the heater matrix, easily sorted by undoing (not removing) the white bleed screw on the side of the matrix, whilst the car is running and the heater is set to full, again this is under the scuttle panel on the oposite side to the resistor. Wait until water is constantly seeping out, to ensure all the air is out, then simply tighten the bleed screw.
