slam panel ?
hi has anyone ever put in a slam panel in them selfs i now it need to be spot welded in but wear and how to get out the old now (hammer and chessel)
anyhelp would be helpful
  • Views 769
Best way is to drill them out, you can get special spot weld drill bits, you may damage the other panel using a hammer and chisel
Spot weld drill or grind the metal away on the panel itself if you are replacing it. I've riveted my replacement one on so it can be removed and refitted
most are just bolted if spot welded remember were the spot welds are grind them off and grind the off and bolt the new one back in place and then spot weld back in the same place
