Mk3 Polo Saloon Interior
Right basically.. I'm thinking about doing something with the interior but face the obvious problem that due to the design of the rear seats there is little that will fit.
Does anyone have any ideas? I'm after something that will give a little more hold in the front at least! BUT would like the seats atleast to match!
Not sure if the easiest/ cheapest option would be to just get the fronts and swap the fabrics over on the rear to match? Or if there is another car with the same design..
Any help appreciated :p
Chris
Oh and i KNOW this isn't the correct place for this but has anyone put speakers in the rear shelf? If so what size? I brought the door pods from Phil and have decent speakers in them and the dash now, but want something for the back and am undecided on a sub :roll:
  • Views 1.3k
Hi mate.
I've got a saloon as well so I know what you mean!
I've currently got coupe rears and fronts in mine, to get the coupe rears in you have to drill two holes into the back of the backrest, and there's two holes in the boot already that are perfect to bolt them into, and the bottom part of the bench should bolt straight in.
There's probably a lot of rears out there that'll fit in, and front wise, seats from MK1+2 golf, mk1+2+3polo, Scirroco, Corrado should be a direct fit, you can probably mod the rears to fit like I did for my coupe seats.
You wanna bolt four bucket seats in there,carpet the rear panelwork first and the two in the back will look quality.
hey i also hav a saloon and i hav frnt and bc recaros out of a mk2 :)
yeah mikeymk got the right idea , in mine i got 2 bucket seats rollcage fully carpeted :)looks well
problem with the loon is the rear back squab is higher than all other polo models so even if you get something close the middle panel always will need re trimmed.
Grey rocco mk2 front seats with standard rears or GT fronts with standard rear look ok in passing as they grey all matches but up close you notice the patern is different.
Bucket seats would be different thats for sure! ;) If i come across a GT interiour cheap i might see if i can do what you've done and get them bolted in.
I know what you mean about them looking roughtly the same i think it was some corrado ones i saw that looked pretty much the same even the colour of the pattern shall keep an eye out for some more.
Thanks for the replies guys :)
Chris
