15" revolution RFX 3 piece split rims - £325 ono
hello folks
got these 15" REVOLUTION RFX 3 piece split rims for sale
They were on a metro 6r4, so the pcd is 4x101.6 (4x4")
Centre bore is about 60mm
Currently separated into parts, as i was gonna sell them as spares, but might as well see if anyone want the whole lot
There are 4 3.5 inch barrels/inners, in great shape. no dents!
There are 4 centre sections, 0.5" thick, in need or a repaint
There are 4 dishes :
2 are 2" (need refinish, 1 had dent (see pic))
1 is 3" (good condition)
1 is 4" (looks hardly used!)
Come with all the bolts except 1, which snapped. These are in good condition but the nuts on the back look a bit past it
Here is how the look built up
Dented lip
The offsets obviously change with each dish, but the backspace when the centre is on a barrel is 2"
I believe revolutions need special wheel bolts, but i think the holes can also be drilled out to use normal bolts?
Well thats about it. If you have any questions pm me
I'm after £325 ono
Located in blackpool
Can do deal with delivery
Pm me or text/ring on 07989 339309
Cheers :-)
Edited by iggi
  • Replies 8
  • Views 434
i want these for some reason,how hard to fit to a polo tho? whats the polo centre bore then?wobbly bolts wood let em fit on the hub
and how much with delivery
Edited by mk2f
could do delivered for £350
polo centre bore is 57.1mm
Edited by iggi
okay not bad i have a mk2 golf was wondering if they would fit with wobbly bolts
yes but you would need to drill out the bolt holes as said in description
and spigots would be needed
epic rims ! and cheap as aswell ! good luck with sale buddy ;)
shouldnt need to drill out bolt holes,wobbly bolts will take that movement,just the spigot ring,shame there arent even dishes or i wood love these
PROVISIONALLY SOLD
