leaky mk4
hi I've got a water problem with my mark 4. whenever it rains my passenger footwell fills up with water. it seems to be trickling in under the door but over the door rubber. I've had the panel off and all the drain holes are clear I've even siliconed the panel back on and sealed it, I've had the wing mirror off and sealed that too, but its still coming in, its got a sun roof dnt know if its coming in through there ? any ideas anyone. thanks
  • Views 834
If it's already wet, try using a hose and testing different areas of the outside of the car until you notice which area it is that water starts to build up.
At least then you know where the problem is.
might be the windowscreen sill it was on my car with the previous owner put a hose on the windowscreen to the bottom black trim to fix it shove a load of window sealer in there is what mine had never been wet again :)
the plastic windscreen cover on the bottom of windscreen is quite loose ill go for it 2mrw and seal it up. thanks tried hosing the car down but i was on my own earlier so couldnt really tell.
well it sounds like the culprit its worth a try exacly what we did to my car and now its nice and dry, might want to really dry the carpet out now dont want to make any unwanted corrosion underneath ( a good hairdryering will do tbh :) )
ill give it a go as soon as it stops raining, theres an inch of water in there at the moment so everything will have to be dried out first. think its got to be the problem as the drivers side is tight but passenger side is very loose. cheers
