Golf seats in a Mk3 Polo
Hi, I've been reading topics on here to find out about what seats will fit ect. I've been offered an interior from a mk2 golf gti. I know that the front seats will fit, they are a little higher and maybe wider but run on the same rails. I'm more confused about the rear bench. Has anyone put a rear bench from a mk2 golf in a mk3 polo before? Any problems or tips would be great, pictures would be brilliant too. The only other thing I can think of is to put the fabric from the golf bench onto the one in the polo.
Edited by POLO_ALI
  • Views 1k
the rear bench will technically fit (i've done it i'll see if i can find pictures) however it'd be fitted for decoration. you can't actually bolt it down to anything, i guess it's be possible with some modification. but it short it's fit in the gap but not actually fit as the polo bench did.
hmm, ok thanks. will be good if you could find some pics.
I concur. It will fit, but you will need to modify it. I managed to bolt the bottom part of mine down by making sine very simple brackets. No pics I'm afraid
did you have to make up brackets up for the back part of the bench too?
front seats go straight in iirc. as said, rear need modifing.
