Thing's to look for on 1.4L
Hi there,
Going to check out a nice cheap and cheerfull polo 1.4 L after work,,
What thing's should i be looking for ??, She seem's good, Owned by a female since 2002. Decent tyres all service work ..
Mot untill april , So all looks fairly good.
They have said that the speedo is erratic and work's sometime's and not others but no other major fault's . Give me a list of bits to look for when i check it out.. Cheers
Its a 1998 reg :)
  • Views 902
1998 are they the face lifted clocks, what mielage and previous work has it had done etc mot and things would help, mainly rust on the rear arches, sills and making sure the passenger footwell is dry quite prone to leak if the clutch pedal clicks beware... :) more info would help
She has looked after it very well, it has always been serviced and any work required always done properly. The tyres are all good, it starts on the button and I thought it drove very well. The V5 is in her name.
bad bits : Drivers door lock broken--can lock/unlock from inside only. Passenger door fine.
Speedo erratic--works when it wants too
Mark on Rear bumper
Needs a clean
Good bits: Loads of history all paperwork old MOT's service book handbook original wallet spare plastic key V5
Face off Sony stereo
Airbag , PAS,
This is all i know from the add, I will look for the obvious bit's ,, I'm only after a cheapo runabout to last me a few months untill the better weather ideally ..
the lock isnt a huge problem,a good haggling point
either replace the lock or just fit remote locking
sure youll pick clocks up cheap?
just check for rust,and listen for noises while driving it,whines or knocks
Cheers , Nothing majorly big to look for on polo's then ??.
As marckid said, Damp in passenger side and clicking pedal..
Obvious things like mayo under cap, Knocks and bang's whilst driving blue smoke , things like that i guess :) ..
As i said doesn't need to be perfect , Just do 20 ish miles a day :)
well polo things are if the clutch pedal clicks you could be in for a nasty ride with a vw :/ i brought mine already fucked really a bugger of a job and theres so many 6ns if you are in doubt you can always go for the next one if your that worried, sounds alright if the door thing pisses you off just get a lock from a scrappie might even be a easyish fix tbh :)
