roof gutter trim...
any body found new gutter trims for mk2 coupe anywhere? do vw still stock these sort of things??
cheers. stumpy.
  • Views 2.3k
Long obsolete from VW.
It has been mentioned that some classic Mini reproduction trim may fit, but no one has been able to confirm.
best bet is a scrap yard on a hot day and take your time twist and lift.
cheers fellas. I've tried mini gutter trim. wrong profile... scrappy in wales with a mk2... i think not... are breadys fitted with the same trim as a coupe?
Breadys and saloons are different. But you can still get the saloons from VW
Mk3 coupé ones should fit Mk2 coupés.. I think! :)
is there any skill to removing/installing the trim or is it just endless patience?
Endless patience and a blazing hot summer's day.
Bready's are bready's and coupe's are coupe's. You just cant swap the two different shapes.
Loon's and coupe's probably share the same,but i dont know for sure.
If you cant do the hot sunny day for us yet,warm by slowly pouring near boiling water along it. Technique is to lift from underneath,starting at the rear.
