rear view mirror removal
I'm trying to get the base off the windscreen for the mirror so i can spray it black along with my other bits iv just sprayed. I've got the mirror off but the base I dont dare do, I've seen people on here say pull it and twist it but that doesnt seem to work
any help would be appreciated
adam
  • Views 1.6k
Are you talking about the arm yes?
If so it should just twist to the left and come off... I wouldn't try taking the small black connector thing off the windscreen as i doubt you'd get it back on...
If you do get the arm off, make sure when you put it back on that you make sure it is straight before applying some force, as this could crack the windscreen (according to Pheonix Windscreens)
Good luck mate 8-)
thanks alot fella, I've put the mirror back on and ill spray the base when i dare :p
If the base does come away, Halfords and other motorfactors sell a special adhesive kit for re-attaching the base, it's like a fine mesh and superglue
Good luck mate 8-)
yeah just cracked my f**king windsreen putting interor mirror back on :@
  • 5 months later...
does the mirror just pill off the arm?
got some 3d carbon fiber on order and want to wrap it
:D
