Can anyone tell me why this happens?
This bolt is from my hubcentric spacer - It has happened to a few of my bolts, particularly from the rear and one has snapped already :x
  • Views 1.3k
too tight? looks like it has stretched? the threaded part looks wider at the bottom, compared to the top
Strange :?
Too short maybe? But then they just shred themselves normally
if its come loose and not torqued could have chattered in the hole causing that.
But that looks typical "necking" caused by excessive tensile force. Too tight. incorrect seating in the whole. As in chamfer or dome seat.
Edit - fuck tard spelling
Edited by neil_dubgt
Cheers guys - Might make sense, as I always found the bolts working there way loose so I'd tighten them up a lil more than the torque wrench advises
Brings me to my second question: What size bolts will I need to replace these (6n2)?
if thats the bolt holding spacer to hub i would be using loctite no doubt about it. that looks stretched to me. use a torque wrench on the hubcentric bolts. i put a set on a jeep they were 3inch hubcent spacers i loctited and torqued the bolts all good so far.
Yeh i was in the process of adding locktite to the bolts when I found one bolt snapped and the thread stethched on multiple bolts. Just need to get new bolts now. Thanks
