Non-bike carbed mk3 16v
ok I'm toying with many ideas of what car to have/do with next.
I'm thinking at getting a cheap mk2/3 loon and AFH'n it.
Id rather keep it running stock injection due to reliabilty and costs. But i know there are problems with doing that.
Has anyone run a afh'd mk1/2/3 not using carbs? if they have I've missed the build thread :lol: I've spend 3 hours trawling club polo :lol:
Problems?
immobilser, coded ecu to clocks ect?
wiring?
Sorry if I'm being stupid and missed a full guide on how to do it somewhere :retard:
coinsidently i have 2 sets of bike carbs sat in the back of the GT atm :lol:
  • Replies 22
  • Views 1.6k
PM Skoda boy, hes running an injection setup, though his is a mix of gti/afh inlet & injection also
Its more simple than running it on carburettor's , The loom just needs to be sorted out of useless bits and bits you need.
Guy is your best bet as he's done exactly what your wanting to do.
PM mclovin
M
sweet thanks for you help guys :)
I may be looking to do this in the future, so if you end up doing this, could you post up any findings :).
Id actually go as far as saying carbs are easier tbh haha
The loom is a work of art :lol:
Ideally you want to run the 16v alternator, which means bodging the mount and also cutting some chunks off the alternator.
You will need some of the interior loom, this has to match the engine loom (there are late and early looms, the both wont go together) You will also need the coded keys and transponder etc that match the ecu.
But as said, Guy is the best man to ask.
Cant think of anything else. we had a few problems doing it in dans, but that was due to it going into a MK1 bay more so than anything else, as theres no room :lol:
the problem is matt that you are a gay
the problems that happened with dans were mostly through the miss match of early/late spec looms and a good 30 miles between his house and mine.
all you need is a full late or early spec loom and it's a piece of piss, just ask toby how quick it was before i had a loom knocked up for dan, problem was we didn't take into consideration the differences between late and early, so i made an early loom that couldn't match up to the late spec injector loom. also how hard is it to concentrate with toby rubbing his hands around his cock claiming he was just 'keeping his hands warm'?
Guy my fiance won't be to happy haha
main reasons for not usin carbs is the seen tax on the parts now, dizzy sometimes fetching 50quid is rediculas.
For using stock injection it's probably best getting a full doner car then u have all the loom, ecu ect.
Cheers for all the help chaps.
i made over 300 quid off the doner car that gave me my 16v lump, and that was after keeping all the bits i needed.
matt give me your fiance and i'll make her happy.
Guy, she just said "no" haha
may bring her to the polo show and she'll give you a good spanking for a few notes.
or you may loose your lady to a real man? :lol:
mate any thing you need to know about this drop me a pm and i'll try and help as much as i can. hopefully i'll be a bit more sober when i read it :grin:
I will as soon as I get a non gt'd polo, if that happens as I can't stop having them :lol:
:lol: :lol:
tbf, you did get it done quicktime.
All we could hear was 'snip snip' for a while then we looked around to see wires everywhere. It was scary but you somehow managed to make it all work :lol:
I'd have just sat there and cried tbh lmao.
guy is good at messing with wires cause he has a small cock
Coorect. He uses his Wang in coke machine slots to get free diet coke.
:lol:
yep, experience with playing with my long piss thin cock gives the edge when it comes to playing with wires :lol:
carbs easier than efi?? wtf? you don't need run and hide behind your clockwork ignitions you know!!
i could help you with the wiring, it's easy on an afh engine, you don't need the clocks or anything stupid like that.. you will need a immo box and matching key but that can be sorted easily..
the best way by far to do it in a mk2/3 polo is to use a bog standard skoda felicia 1.6(aee) injection loom as it uses the same magnetti-marelli 1av ecu type as the afh engine so the pin-out on the ecu is identical! , i've done a couple of polos in this way, all you need to do is slightly move the throttle body plug by unravelling the insulating tape and seperating it from the map sensor plug then re-taping it... then all you need to do is feed a permanent live, switched live, rev counter wire, fuel pump control but all those are on the same multi-pin connector.
lol, the only reason i said that is i hate electrics.
I'd rather mess with carb related stuff over wires anyday haha
Forget all this nonsense Matt - I have a present for u at my gaff to get u started on 8v carb set up...
yeah i hated fuel injection systems at first, but to be fair you can't beat them for reliablity..
i like playing with old-school carbs too, i've got a kosher little 1.7 alfasad ti with quad dellorto downdraughts on it
Oooooooo, what might this be :D, still need to give you tez's dizzy too :)
you free today pal?
:lol:
