original polo 6n mud flaps
I've got the original 6n polo mud flaps and I'm woundering if anyone knows how to take the front ones off as I'm having a slight problem with them
If they're anything like putting them on then they're gonna be very hard to get off! lol
Undo all of the screws first (obviously), then try pulling the clip off at an angle, it might be worth unscrewing some screws and trying to push the plastic in the wheel arch back a bit so you can gain more access to the clip!
Someone else might have a better idea but that's what i thought if i ever had to remove them!
Good luck mate
the clips the bit I'm stuck on which angle you pull it out and which way
