Windows Condensing....
Ever since i've owned my car the windows have steamed up/condensed anytime if there are two or more people in the car or if it is slightly moist. (giggity).
When it rains it's horrific. I've had a demister pad and other cloths to get rid of it before but the only two windows that demist are the front and back windscreen. All of the door windows are steamed up to a point where you can't actually see anything out of them, and opening a window only seems to help a bit, but isn't really practical when it is tipping it down.
I've never really minded this as such and have learnt to put up with it, however it's got to a stage now where it has condensed so much and drops of water have started to streak down each window. I had to rinse out my demister pad and then go and grab a spare flannel :/
I also found a bit of water built up in the boot catch (only small), and the metal frame of the car behind the lights (on the inside) has also condensed and got water drops on them, along with the suspension mount caps...it's not large water drops but is still there...
I know the seals are fooked, however was just wondering where abouts I can get new seals and how easy is it to replace them (properly)?
Also want to know if anyone else's car has a problem to this extent?
Btw hope this is the right section for this.
  • Views 895
Went out to the car this morning and the inside of the windscreen was iced over aswell as the outside :|
Large air leak or? :/
i to have to de-ice the inside of mine... bet you've never had a frozen seatbelt???
hmmmm
I have similar issues too, leaving work today my windscreen was totally steamed up. And I have also had to scrape ice of the inside on occaisons too
hmmmm
LOL, no I have not yet! haha
Yeah it's a pain, been getting worse lately.
Gonna look into getting the seals replace anyway lol
