Track day 105db limit
I'm doing a track day at Oulton Park on the 9th February and have noticed it has a 105db limit. It's my first trackday and was wondering if my GT with a 4 branch, decat and powerflow backbox will be anywhere near failing that? I've no idea how loud 105db actually is :D
  • Replies 17
  • Views 2.5k
if you've got an iphone (i'm a geek) then just download a db tester. I know theres one that goes up to 120db, as I need it for my job!
might be something similar you could get for other phones if not??
if not swing by a local band rehearsal rooms and ask if they can test the db level, they should have a meter for hearing protection policies. You will either get a grumpy 'geezer' that looks at you funny and tells you to bugger off... or the whole rehearsal rooms will be out having a look :)
We measured the loudness of our extractor fan at work last week at 88db and that is LOUD I doubt your car with them mods will be near 105db
105 is stupid loud or equivalent to a stock 996 GT3 at 4500rpm @ 2m.
the test is done differently to each track but normally they ask you to rev to a 1500 below the redline (on a polo 4500rpm) and measure it from 2m.
but tbh there is a fair difference in noise between being parked up and revving to blasting past at full throttle. Only way you would get to 105 in a polo is with no exhaust at all.
Edited by Cymro
you haven't heard how loud higram actually is, its ridiculous haha
People complain about mine on the track but in the static test I always pass.
Had a copper pull me in Cardiff about the noise and asked me to rev it up to get a reading and it was well inside the limit for road use.
Some tracks have much lower limits than that so 105 is pretty generous.
Edited by Cymro
it is loud you 'should' be ok but the only way to know is get a sound meter and rev to 4000rpm and see. Or head down there on a track day before them and ask them to test you. Nothing worse than turning up only to be told you can't go on.
you can buy sound meters on ebay for about £30. It's worth having one as you wont get a refund if you arent allowed out on track because you are too noisey. Although I don't think I've ever seen this actually happen yet, 105dB is bloody loud. I've seen TVR Cerberas pass it and they are stupidly loud even as standard. I've also seen a Honda Integra Type-R pass which you could hear over everything when stood in the pits no matter where he was on track when ever he floored it (wasn't fast though ;) ).
In short, I doubt you'll pass it if you have an exhaust that actually has at least one silencer of some sort.
Also some circuits now have drive-by sound meters at the sides of the track at various places, it's easily possible to pass the static test but set off some of these and will also get you black flagged. No easy way of doing this test but if you do your own static test and are way below 105dB then you'll prob be OK.
sorry that its nothing to do with the 105DB limit but i think I'm going to be doing this trackday too :-) ... in a my spare purple 5 door 1.4 6n :-(
See you there :)
Edited by kylep943
my friend has a mini that static produces 96.9 decibels and that really is loud but it sounds awesome and thats with no silencers at all so you should be ok
Cheers everyone. I've just downloaded a couple of db meters for my phone and will see what they come out with. If it's consistently near 105db with them, I'll buy a proper one and see what that's saying.
Kyle: if you do go, come over and say hi :D
Matty: Is that Emz's? Hers is way louder than mine I reckon, so I should be ok.
Thing is you could be at 102db and not worry in the slightest as every 3db increase is actually double the sound strength it was before, if you see what I mean.
Put it this way, 98dB is the threshold of pain.
I thought pain threshold was around 125?
well a 747 at full chat is around 140db
Don't need much to make a polo loud, for proof, I just got pulled by Northern Constabulary and requested a decibel check, 97dB at 3/4 revs, calibrated meter.
That's with everything standard other than the backbox btw.
Edited by alexnessie
97db at 3/4 rpm is perfectly acceptable. 98 is the limit for road rallying, 102 for stage events. Metro 6R4s quite happily go through the 102db test and they suffer because the exhaust is short and you also pick up alot of intake noise from the test!
I should be ok with the limit then.
I've decided that it's too loud for me though. I'm getting a new centre section made up with a silencer in, it's doing my head in on the motorway now!
As a rally radio marshall, if you've ever seen or heard a 6R4 at full chat in the forest you would know how loud they are, so I doubt if any Polo would come near this limit!
