matt green re-spray
just wondering if i can get some info about re-spraying, will be using matt green spray cans. what prep and other stuff will i need to do. thanks
  • Views 817
Mdont do matt green!! Lol i did my arosa last year in it and it looked horrid! Least to say the BAD attention i got, i ended up stealthing it out chalkboard black, you are choice but just giving out some wise advice to help another
If u are to go ahead... Green.... Then you need to flat it all out about 600/800 wet and dry, depending on if you want it to last you can either put a ligjt primer on or just go straight to colour(i went straigut to colour) put you first coat on in a non dusty enviroment (meaning you are front drive lol) then build up coats when it becomes dry if its matt you dont need laquer just keep some paint hamdy for when the weather starts to get at it
Hope this helps...
I would use 800 grade paper if you just using spray cans, make sure you give it a good clean with some degreaser aswell. Also don't just put a full coat on first just give it a light dusting to start with
