Sunroof problems
Hey,
I've got a mk3 Polo Genesis and I'm having abit of bother with the sunroof. When I got the car there wasn't a panel covering the metal part of the sunroof, which I recently just purchased. But before that I've noticed that the sunroof doesn't seem to go all the way back. The previous owner told me that he had changed the seal so he probably removed it and hasnt put it back in properly.
So basically I'm asking how to I remove the sunroof or what could be causing the problem with it not going all the way back?
Cheers,
Rob
  • Views 1.4k
could be the wee mechanism at the back its just a wire and if it get shit in it it can Jam.
Removel is very easy and i would advise doing that to fit the panel anyway.
was the panel missing before or could it be jammed at the back stopping it going back?
its real easy job to show someone but it explain its a bit of a pain in the ass.
heres a diagram that might make it a bit easier to understand.
if its not winding back i would disconnect all the linkage then push it back by hand
basically to get it out you need to wound back as far as you can, remove all the bolts then wind it half closed then forward and up and its out.
if you get stuck pm me or i can try explain it on the phone.
if you kill it dont worry i have a sunroof you can have for the price off postage and wrapping then just swap your red panel over.
Edited by genesisGT
  • 1 year later...
Can anyone help me fix my std factory glass tilt/slide sunroof on which the glass appears to have "jumped out" of the mechanism on one side. I've removed the whole thing from the car, but am now at a loss to know how to pull apart. Maybe this is why Haynes said "don't attempt"
It should be the same principle as above, I would imagine.
From what I under stand you have to remove the bolt holding the cables in place then remove the panel.
But as said above its easier to do then explain.
I spotted the screws holding the glass panel in place. When I removed the glass, I can see that a die-cast part of the mechanism has broken, so I need to get a replacement unit.
