Few problems. cooling fan, heater fan, horn and more?
Hello, my polo is almost ready for the road and now have a list of the final problems. Didnt want to make 3 different threads so hope this is ok.
Well the problems are that the engine cooling fan doesnt work, the interrior heater fan doesnt work on any speed, the horn doesnt work and the windscreen wipers dont work.
1st question might be quite stupid and that is, where is the horn located? i have looked for it but cant find it. So my guess why it isnt working is because it just isnt there :p
2nd question, the engine cooling fan doesnt work, what can i do to figue out what is wrong? where is the main places it can have the problem?
3rd, the interrior heater isnt working on any speed, so also what can be up with that?
the windscreen wipers dont work, but i have that on a thread from before so i dont need to bring this up again? :)
Are any of these problems related? maybe run on same fuse or hook up to same relay or something?
Sorry for all the questions and that some of the questions are in the wrong section but i thought it would be easier and better to put it all into 1 thread instead of making many.
I have 2 more questions about what the part is from the engine bay, but they are not so important and they will definatly be in the wrong place so i will stop here and hope for help to sort these problems out.
Thanks Adam.
  • Views 698
first place as you already suggested is to check all your fuses. now if you think your horn is missing (different) the OEM one lives on the drivers side of the vehicle mounted on the 'slam panel' next to were to where the centre spots would live. As i understand it a common cause of rad fan failure is the coolant sensor, this is mounted on the rad between the inlet and outlet hoses.
Yeah horn was missing I found the cables tucked away haha.
Also the cooling fan.. There is a plug on the fan and then 2 on the thermostat, which is the plug to the fan? And how could I check them and the coolant sensor as steed says? And where could I buy one if It is broke?
Thanks Adam
