Adding Fog Lights to Mk5 5dr e, any help?
I have seen lots of mk5's with Fog Lights but never quiet been able to work out how or were i would be able to purchase or fit them to my car. Also looking to resparay the front bumper as it is looking worse for ware. Any tips or pics people have would be helpful.
  • Views 2.2k
You need the following - all available from eBay:
Fog lights
Grills with fog cut outs
Fog light switch
That's all you need, the wiring loom is already there behind the grills, simply plug in and play.
To respray the bumper I can't give any tips because I get a bodyshop to do my painting. About £200 for a front bumper if your not having anything else done is the going rate if you go to a 'reputable place'.
Sorry didnt get an email to say anyone replyed, I will have a look to check to see if there is a loom behind the bumpers, and if i get front fog lights how would i give myself rear fog lights?
there are plugs behind the outer lower grills (pluged in a blank clip on body) remove grill fit fog lights fit new grills with hole in fit light switch with front fog position on then all lights work as they did before but with front fogs
you already have a rear fog light.........
I dont have a switch to activate it, the switch on my dash only allows me to turn dipped headlights on, and full beam on stalk. So i am unable to turn it on i think. Will i need new grill pieces for were the fog lights are going?
Put your headlights on, then pull the knob out, that activates your rear fog. Front fog is the same, but the switches have two pull out positions, one for front fogs and two for front and rear fogs.
It is a 6n2, and i will try that once i get back to the car, you sure about this because i dont want to rip the whole thing out lol
