mk2 and mk3 5speed ARB, difference?
went to the scrappy today, and was looking round at these two polos, one been a mk2 and the other a mk3, both where 5speeds. but the ARB were different.
I was always lead to belives the 5speed arb's are all the same on the mk2 and the mk3, and the 4speed different to the 5speed.
any one enlighten me???
  • Views 1.3k
Think the difference is where the downpipe bend clearance changes in the mk2's.
so would or would i not be able to use the mk2 5seed arb on my mk2 coupe which is going to have a g40 eaton engine (basicly a mk3 engine)?????????
joel
just seen this is in the wrong section PLEASE move mods :D
anyone know
I'd use the later mk3 5 speed one if you have the choice. My mk2 5spd arb is symetrical so to speak where'as the later mk3 one is offset as nick mentioned presumably to clear the twin downpipe.
I have a freshly powdercoated satin black one if you need?
The MK2 one is better for ARB castor blocks,as the MK2F (3) one gives problems when fitting the centring clamps. And the bend in the earlier one is wide enough for any exhaust,clears my twin flexi AFH downpipes (with castor blocks).
Castor blocks? The same as g-laderseit arb blocks yeah?
