help! polo suffering with condensation......bad!
hey everyone bought my self a nice mk3 polo gt, problem is after several days of heavy rain i opened my car door to find i had a rear foot well full of water and also across the top of the dash!
i cant work out what is causeing it, the thing thats most destroying is that I'm willing to spend money on it but with constant dampness and mould growing its really swaying everything in the wrong direction. plz if anyone has the same problem or any advice please help. thanks! :cry:
  • Replies 15
  • Views 4.6k
i get some condensation not to the same degree you are spking about edd but i put it down to the weather with it being so cold at night .The only thg i would put yours down to is the seals around yr windscreen and door have perished or your the holes on the tray below the grills are blocked so water is seeping through the back of the dash? i could be wrong but i found that with an old Astra i had
lots of places water can get in. Some common ones on mk3 polos can be:
- rear light cluster seals
- door membranes, remove the door cards and check the condition of the plastic membranes behind, even a smallish rip or part of the plastic come unstuck will let water into the car instead of draining out of the bottom of the door where it is supposed to go
- rust around the windscreen, only real fix is to remove the screen and repair the rust. You can bodge it for a bit by squirting some silicone sealer behind the seal where the rust is but this is only going to be temporary.
- sunroof. If it's a factory fitted steel sliding one then check that the drain holes from each corner of the sunroof tray are clear (poke some stiff wire down until it comes out of the other end, which are near each wheel).
thanks guys really didnt think id get a reply, ill try all those things out and let you know if the problem stop, thanks alot!!
also take the battery out and check under it for and rust holes
Yah! Can't believe I forgot that one. Prob the most common one!
i've got the same problem, went to my car the other day to find an unexpected puddle in the driver's footwell, i'm 90% sure it's not a leak though and it's condensation. dunno what to do about it really, it's not been as bad as it was though since, just a little bit of dampness usually
does condensation mean perished seals somewhere or quite simply cold weather?
thanks
Edited by owengd97b
I've got no leaks just silly amounts of condensation think its just down to the weather.
I had quite a bad rear window condensation problem which I eventually traced to the boot lock seal which was knackered. I bodged a new one out of some kind of rubber mat type thing we had lying around and it's improved - maybe worth checking.
actully dude my boot look dont work and there is no door card on it, its a fucker cuase i have to get in the car and pull the cable to open it, do you think it could be becuase of the fact i have no door card and the lock is fucked.....i guess thats the only logical thing it could be....but would that give me water across the dash and roof on the inside too?
bastard i pulled that plastic stuff off behind my passenger side door card and not i know why it looks so rank .cause the dam waters getting through :(
where do you get the plastic or what else could i use?
I get really bad damp, in my boot but it seems to rise up as its only ever underneath the carpet thats wet, what could that be? I tried tracing it and all I could think it was the rubber gromet with a wire going through it to the underside of the car (reverse lights?) So I used bathroom silicony stuff to cover the grommit but its still leaking, what could that be?
pop to a garage and jet wash it,but only on the shampoo setting
then check inside for water and suds coming over the door,window and boot seals,i was getting a damp passenger footwell and it was the bottom of the door seal letting water in
Edited by gaz2k
i saw shampoo running down the inside of my passanger window once......
apparently it's best to wash a car with them done up???
whoops
whoops
good one :lol:
I get this and have never been able to find why, re-sealed all the lights, checked the boot seal and still not sourced it. Thing is i carry a 5l bottle of water in the wheel well and its not leaking but always has a lot of condensation on it.
