HELP ME CHOOSE I NEED EXPERTICE!
hello I'm in a bit of a pickle i have a black 6n2 and i dnt no what to do headlight wise i was thinking hids or black fk angel eyes or both or does anyone have any suggestions?
HEEELP I'm IN NEED!!
thanx
  • Replies 19
  • Views 1.9k
apparently HIDs are gonna become illegal on cars that didn't come with them as standard so i'd stick with standard ones but smoked....
HID's ARE illegal already. They have been since Dec 2006 IIRC. So as above, stick with the standard ones. Put HID's in and at some point you will get stopped. Especially if these changes to the MOT come in, then you won't pass an MOT either.
i heard that exact same thing hid's will fail m.o.t
i agree standard ones look better but each to there own
My 8k kit just passed an mot no probs
Currently its a grey area (Ie, if they are obviously badly fitted or dazzling everyone there illegal) and down to the tester (currently having any sort of blue tint will fail you anyway), but from Dec this year it will become supposedly be illegal to sell, fit and use HID's on a car that didnt come from the factory with them fitted.
I've passed the last 4 MOT's with HID's fitted, perfect beam alignment and pattern.
Thing is this new law does not allow for aftermarket headlights that are designed for HID's as normal they have just put a blanket ban on it because of people with no clue about fitting them to lamps with poor beam pattern, Mk2 Saxo being a prime example as the very open shape headlamp just scatters light everywhere and has no definable pattern.
This new law will now open the gates for the restriction of other currently legal aftermarket parts.
Edited by Cymro
Oh I agree entirely that this is very very grey. Currently I don't think they will fail an MOT unless they are really badly fitted/aligned, however unless the car has approved lenses, self levelling systems and headlight washers fitted then they are illegal.
See here - http://www.dft.gov.uk/pgr/roadsafety/drs/hidheadlamps
Trust me, this comes up a lot on the 306 forums! Like you say, grey as grey but still illegal according to the DFT (unless lenses/levellers/washers). Sucks because when they are fitted correctly they are brilliant, especially on dark country lanes!
90% of the time when you see HIDs you just get dazzled to death. Yeah its good to be able to see the road well but at the same time that doesn't mean you should have lights so bright and badly aligned that the person in front of you can't see anything for the black spots you've just burnt into their eyes.
could you not fit hids into spot lights? Then you could flick them on as and when needed (country lanes for example) and flick them off if some one comes the other way? 99% of the time there is no need for such brightness any way and as said it just makes it more dangerous for other drivers.
it also makes it more dangerous for the person with the HIDs, if an onoming car is dazzled and cant see..... who are they gonna have a head on collision with...?!
d
ok so your saying if i get hids then get them properly set up? if not shall i get the xenon h7 bulbs not the full kit?
does anyone suggest a make of smoked headlights?
I think what McLovin said is the best idea. I'm going to ask a really stupid question here, but are the dip beam and full beam separate bulbs? Or do they just have 2 brightness levels, or something that makes them dip?
Because if they are separate bulbs, could you not fit HID or very bright bulbs to the full beams, and leave the dip beams standard? 'Cause as soon as you see another car you will dip your lights, so the oncoming car will not be affected.
Edited by Fisher..
I *think* the Polo has separate dipped and full beam, so (if that's the case) you could get away with putting the HID's in the full beam. However, HID's need time to "warm up" because of the way they operate. So, if you keep flicking them on and off (for instance when somebody has given way to you) the bulbs will appear blue (no matter what K they are), which could look as though you were a police officer, which in turn could get you pulled.
The other downside to using them like that would be that you would damage the bulbs as they aren't meant to be used in short bursts, constantly switching on and off. Although of course at the end of the day it's down to you what you do!
How about bulbs like Philips BlueVision? They claim to be Xenon effect and I assume that they are legal, but what do I know? :)
On my old mk2 I just bought some cheap white bulbs they didn't last that long (about 9 months) but they were cheap and did the job
I'm not being funny but I bought some cheap Aldi bulbs (think they were £3/4 a pair) and they are really good, really bright. Not sure they've got them in anymore but when they do it'd be worth buying some for what they cost! And most definitely legal!
But yes, those Philips, the Halfords Advanced/Pro thingys and the other Super Brilliance bulbs are all very bright and legal.
I'm pretty sure they're okay MOT wise if they're properly fitted and have the correct beam pattern and aim. as for using them in Full beam, thats DEFINITELY not allowed. as the bulb has a delay as you turn it on, and then takes more time before reaching full brightness (as you said). i think if you used them in a 6n2 it would be okay, as the dip bulb and full beam bulbs are different bulbs (H7). and the dip beam uses a projector which'll give you the correct beam pattern. so you could have dip as HiD and full beam as a halogen bulb. I'm not so sure about about HIDs that are the same bulb for dip and full (H4 as is used in the 6n) you'll have to find a set that have the correct beam pattern.. (i think thats right)
Edited by R0yaL3
so your saying i could use hid h7 as my dipped beam?
MOT wise I think you are OK if they are fitted/aligned properly etc, for the time being at least. If these new rules come in to force then you would fail your MOT if you had HID's in. However LEGALLY they are still wrong, and if you get pulled over by a policeman/woman who knows what they are talking about then you would get done for them. Is it really worth it? As I said above, I bought some cheap Aldi bulbs and they are great, not had any problems with them and they are plenty bright enough.
That may in fact be what R0yal is saying, however as I said they are still illegal unless you have lenses which were designed for them, and you have to have headlight washers and self levelers fitted.
It depends if you have a 477 or a 472 bulb in your car, if you have 477's (slightly smaller than 472) you will have separate bulbs for dipped and main beam as they are single filament, however 472 bulbs are double filament so its both your dipped and main beam in one, I'm not 100% on what is in the 6n2's but if you cant see in the headlight to check you can always take a look at the terminals on the back of the bulbs, the 472 will have three terminals and the 477 will have 2..
472 shape ,-,
477 shape , ,
