6n Dewiper
I want to dewiper my 6n and i have used the search function and i have looked through threads but why does there seem to be two different ways of doing it on a 6n? One where it leaves a big semi-circle out of the window and the other which is simply a grommit?
  • Replies 10
  • Views 3.8k
well,
you have a hole in the metal boot lid you need to put a gromet it. some people leave it at that.
but there is also a D shaped cut out in the glass, people stick a blank over this to make it look better.
some people reuse the plastic surround from the wiper mech when they remove and fill it and smooth or just put a blank in it
what i did was:
1. take the base plate off the wiper arm
2. stick a 2p on the back
3. fill the hole with fibreglass
4. smooth over with filler
5. aerosol primer and matt black it
6. windscreen seal it to where it originally was
was easy for me cause i work in a bodyshop so have all the materials i needed.
it looks alot tidier than just sticking a rubber bung in the hole.
I know its not the best pic but i would want it like this...
41043_426744717372_598412372_5553502_150
I've just done that to mine and looks exactly like that...
Put an aerial grommet from halfords into the plastic plate that comes off with the wiper and then silicone it back onto your window...
Now i just need to find a way of re-routing my rear washer pipe so that it will shoot water from the front of my car 8-)
Do you know the size of grommet mate?
:lol:
Do you have a Halfords near by? If so then they sell a pack of 3 aerial grommets 19,22 and 24mm
I think the one i used was 22mm...
Was it easy to do, like i know how to remove it all but did you seal the grommit in or just put it in?
Just go for it and stop being a fanny lol, it really is self explanatory.
I will do it, probably tomorrow but just getting clued up ;)
