1.4 16v cams
anyone know were i can get a hole kit from for a decent price? let me know please :)
  • Replies 8
  • Views 1.3k
if you want new units made from blanks they are anything from about £600 upwards, but for a re-grind on the original units it's roughly £300 for the pair
nice how do i go about geting them re grinded? what needs 2 be done?
Think Newman do regrinds iirc. Contact any of the big cam manuactures, they'll soon tell you
Machinemart, £10.79
Ring up piper cams, there re profile your old ones to I think stage 2?
There doing mine, and it's £210
^^ excellent stuff that, think i ought to give them a bell
yeh think ill be phoning them up this week and seeing if i can get the same sorta price =D
when you say the reprofile them, how does this work and what are the gains?? I know you buy cams and it adds bhp and I've seen people saying theyve got a 268/268 shcrick cam or whatever...i dont wanna know how the cam works with the lift and duration but how do they make a standard cam into a more performance based one
Material is ground off of the bottom circle of the cam lobe, the top of the lobe remains the same height but the lobe is machined flatter, lift is calculated with the difference between the diameter of the bottom circle and the top of the lobe.
Heres an example i drew up, its fairly exaggerated.
Some say that re-profiled cams can have detrimental effects to the cam followers as they would be operating beyond their manufactured specifications.
Edited by mattway
