HELP POLO REAR DOOR WONT OPEN !
5 DOOR 2003 9N No faults......done a full scan and nothing..........its not electrical .
took off the door panel,when i pull the cable from the inside i do see the mechanism moving and when i lock/unlock the door i can hear the central locking unit(in the door) working aswell,tried everything but still cant get the door to open!
I dont know why its jammed and weather my next mission is breaking the central locking unit then some how trying to get to the lock(if it can be done) I'm thinking the unit and the door lock are 1 unit or just fixed together?
I think obviously the lock is stuck on the door jam and the only way to take the lock off ideally is to open the door and take out the 3 bolts,,,,,,,,but it go's back to square 1...I'm having problems opening the door in the first place! Luckily I've been told its not an m.o.t failure as its due in 4 weeks.
  • Views 3k
i had the same thing... took it to the garage and it needed a new central locking motor...
MARC9N how much did it set you nack ,,,,,job done.......any ideas what/how they opened the door?
they pulled the door card out with a crow bar haha. and not too much for the part but it took ages to get in the door so labour cost a bit. i had to drive about with wood propping my window up because the part was late... but was less that 100 it should cost too much....
