mk3 window winder - snapped cable.
Hi all.
I recently bought a mk3 coupe - It's got a couple of small issues. One of which is the n/s window......
The winder wouldn't move and the window kept dropping about 3 inches or so when driving. I took off the door card and found the cable has snapped. I'm not sure what this will require to fix so i'm hoping someone might be able to help out...... Will I need a whole new window setup? Or can i just replace the cable? I didnt go any further taking the door apart because I don't have any parts to fix it yet, so I'm not sure how easy it will be to remove all the bits.
Any help would be greatly appreciated!!
Rich.
The winder mechanism comes out fairly easily as a unit, so just swap it with another one from a mk2/3.
You can replace the cable, thats what I did on mine, a few months ago now and its still held :D I cant remember how I did it now though...
Easiest way is replace the whole mechanism bit. its fairly cheepish too.
remove the door card and gently remove the water barrier ( dont stanley knife it or you will need a bit of polythene to repalce it or lots of gaffer tape)
undo the wee 10mm bolts think there is 4 of them then might need to cut the other side of the cable so the window can be pulled down then undo the glass base bolts 2 x 10mm then squash/ wiggle it out.
new one is wiggle into place,
do up the winder and vertical bolts then wind down fit the glass and move it up down check its happy then tighten them fully up.
heres one here:
ebay link click me ( they are left and right handed so make sure you get the right one).
but could get one for abotu a fiver out a scrappy or off here.
Edited by genesisGT
