polo 9n3 1.4tdi common faults?
As above really
  • Views 8.6k
I'm not 100% sure if the 9n3 are still using the 3 cylinder diesel units like they did in the 6n2 but common faults on that engine are oil pump chains snapping this has happend on mine now & I've read about it happending to three other peoples engine as well. sadly to refit a new chain ( if it hasn't whipped out the engine already ) you have to remove the engine & box from the car & strip the bottom end a new chain from tps is 30 pounds & the guide & tensioner 30 pound again I'm going to fit a new pump as well for peace of mind thats 130 pound . Again I don't know if this is a common fault or just age related wear on mine ( car is 11 years in with 91 thousand miles ) but I've found a lot of play in the turbo so I'm currently looking for a recon unit on mine or a new turbo at circa 400 pounds again I could be wrong as I'm not sure if VW have fixed these common Faults on later engines . But other than this a well looked after & serviced engine is good for around 250 - 300 thousand miles they are good engines & return really good Mpg's & are rather powerful & Torquey engines being only a 3 clylinder design
Hope this helps
thank you for your answer but i wld imagine that vw would have solved the oil pump chain problem if I'm talkin about a 9n3 and you are talking about a 6n2
Wishbone bushes are the most common I'm pretty sure every car built on the 9N/9N3 chassis will have to have them replaced at some point. They are cheap to replace anyway i got mine done for free as they went on the way home from me getting the car. ut apart form that the TDis are great. My 1.9TDi is giving me 60mpg+ and I'm sure the 1.4TDi will be even better.
