ways of blacking mk3 bumpers
tried satin blacking, back to blacking mk3 bumpers and it never lasts. anyone managed to get there mk3 bumpers back to almost a pristine finish? and explain your ways of doing this..just looked at the bumpers on yoof's mk3 and they look immaculate! post some pics of yours if you will.
how do you do yours?
ben
Edited by ben.r
  • Replies 17
  • Views 3.4k
paint them mate :)
need flexible paint iirc.
where can said flexible paint be purchased? I've got GT bumpers and i don't wanna wreck the red stripe lol. masking tape doesn't stick :evil:
use a heat gun. works a bloody treat, i did them on my passat and my mk2 coupe, they were both rocking grey bumpers till i got the heat gun on them, now the are black as the ace of spades
black spray paint :lol:
back to black looks good for a day or 2
like I've said it peels off and looks gash imo. and fuck back to blacking them every day or 2. may have to hunt down some plastic flexible paint. I've heard of the heatgun trick working but how long does it last?
Heat gun lasted about 15k motorway miles on my front bumper before fading. I'd personally not do it again though - it's far too easy to get wrong and leave weird patterns. Also unless the bumper is immaculately prepared, things like dead fly juice will go different colours. I'm looking at possibly vinyl dying them this summer.
i sprayed mine and aint peeled off ,get some proper acrlyic spray maybe
satin black aerosol from motor factors.
clean bumpers completely
give it two coats.
simples
still well black.
way less effort than below
Edited by mini_mayhem
paint on bumpers should not peel easily at all, they are very rigid structures!
preparation is 99% key to a good, long lasting paint job.
if i were to do mk3 bumpers i'd take them off the car and do the following:
clean them thoroughly with soapy water.
clean them again using panel wipe to get rid of all grease and residue.
spray a very light coating of grey primer to provide good adhesion.
spray another light layer of grey primer and then sand lightly with 240 grit.
spray a solid layer of grey primer, being careful to not let it dribble (keep can moving at all times)
allow to dry over night, or dry thoroughly with a hair dryer.
sand very lightly with 400 grit, then clean with panel wipe.
spray another 3 - 4 layers of grey primer, always drying it and then lightly sanding it before the next coat.
spray with black primer or matt black paint, another 3-4 layers.
allow to dry overnight, definitely do not rush that one.
by now it is ready for the final layers of gloss black if you want it gloss black.
be sure to sand off between layers using 600-800 grit, and then 1200-1500 for the final coat.
to finish the job off and make the paint last a good few years at least, spray the bumper liberally with a GOOD QUALITY laquer. far too many paint jobs of mine have been ruined by shit cheap laquer.
you need at least 4 layers of laquer to make it long lasting.
i just painted boiled linseed oil liberally on my mk2 then wiped of the excess
Halfords bumper paint is what i used on mine.
Started coming off a bit now mind, but its been on well over a year so I'm pretty happy with it.
Satin black paint does a good job too, used plastic primer too..
good call man thanks for that, i take it the bumper was plastic primed before the bumper paint? dont want them fully smoothed and dont want to damage the red pin stripe. want them to look like they just came out of the factory, there in good condition
Apparently smooth peanut butter works like back to black but better
peanut butter mann
peanut butter is wank, it works but makes dust stick to your bumpers like mad, and makes the car and yourself smell like youve fingered a badger.
just paint the bumpers and add plasticiser to the paint allowing the paint to flex
going manc union nay?
