Headlining and Doorcards
Right i've searched and read through the entire length of about 10 topics regarding best ways to change the colour of headlining and doorcards.
I'd like to ask anyone who has changed the Doorcards or Headlining colour (be it with spray paint or sticking material too it) to quickly (in a few bullet points) explain the steps taken.
Lots of people have stated many best practices and so now that i've come to the point where i want to do it, i'd like to know all of my options pooled into one thread rather then go digging up old topics again. Also i hope they'll be enough in this thread to make it a sticky.
So far, i think i'm right in saying:
Remove all 'objects' (roof handles, b pillows, light) from car.
Remove/unclip headlining.
Lay headlining out
Lay out material (bed sheet)
Use high temp resistant spray glue/adhesive across headliner
Carefully press on new material and flatten out bubbles/creases with hand.
Cut 'to fit' excess material away from headliner.
Refit headliner to car.
Am i right??
(also, for those who have used kids bed linen, did just one single duvet cover do the job? was there enough of it?)
Edited by Liquidice
  • Replies 10
  • Views 3.1k
yes a kids single bed sheet does the trick.
some other points would be, dont go crazy on the glue or it soaks through the sheet.
leave plent of excess to fold over the edges as there isnt really alot for the headliner to clip into on the back windows (i have abit of a curtain effect going on because i cut mine to close to the edge)
i want to do mine but i have a sunroof so i wondered if anyone knows if it is dificult to remove the sunroof slider cover and how to spray the electric sunroof switch???
I did mine, which has a sunroof too. It was easy and should be even easier for you as your sunroof is electric, Mine is manual and the cover for that is a pain in the arse to get on and off. Still haven't got it on properly.
Just make sure you buy 2 cans of glue if you are doing the pilars aswell.
I was just doing my roof lining and ran out of glue with about 20cm left to do :S
yeah i will get 2 cans. what glue wld u use?
Trim fix adhesive is what i used. A friend recommended it.
Trim fix adhesive
I wouldnt mind trying the bedsheet idea..
2 of my mates spray painted their headliners black and they came out very well, weird to touch though :p
surly thats would flake off after a while :|
My black bedsheet has worked well, fells good to touch too and improves the car loads imo.
No one believes me when i tell them it's not original and i did it myself!
Dont know tbh, one mate has had it done for a good few months now and its still the same
