Mirror cover removal.
I need to split my mirrors so I can paint them.....
How does the painted section come off?
Had a quick look but dont want to break the stubby I just got delivered!!
Cheers in advance, Lee.
Which mirrors have you got ?
N/S is the original stubby and the O/S is a replacement stubby that I am going to have to fit to the original base mount.
Will be 'cracking' on with splitting them this week!
:shock:
:shock:
Will be interested to see how you get on with fitting the stubby on your estate, I've recently bought an '01 estate & whilst washing it at the weekend, managed to knock the drivers mirror off, which I then discovered had been glued on by the previous owner :?
Am now in the process of finding a replacement & bought a normal 6N2 drivers mirror (which I assume is what your stubby will be) from a lad on here earlier in the week, it came today & I realised straight away the base plates & mirrors are totally different :cry: Think the mirrors & I guess possibly the doors (as the mounting holes dont line up at all) on the POLO estates are from the SEAT cordoba estate, so for a straight fit will need SEAT mirrors.
Have stripped both mirrors out tonight & taken a load of piccys I'll put up over the weekend,
So, to answer your question to split the mirrors (& this took me a while to work out), theres a small plastic/rubber bung near the screw on the black plastic cover at the bottom of the mirror, remove this & if you look in you should see a small metal tab, you need to lever this (I think towards the front of the mirror) which will then release the painted cover, (its quite hard to explain & theres quite a bit of getting your hands in the right place/pinching the right places to get em apart) I'll try & get the pics on here tomorrow as it'll help show you the bits I'm talking about.
:shock:
cheers for the info.
Already done it by the time I read your post!
The mirror still isnt on.....not had time, but I will have to re-drill the car to make it fit as you have discovered!
Will let you know how hard it was......
