Polo 9n3 FK badgeless grille issues
I just got the honeycombe FK badgeless grille, however I just tried to fit it and the bracket for the VW badge on the original grille is too big and sticks out, and i cant fit the new grille. Only way i can see to fit it is to remove the bracket, however i dont want to be cutting stuff if there is another way. Anybody else tried this and had the same issue???? Any help appreciated!!!
  • Views 1.7k
i am about to do the same to my 9n3 let me know how u get on
You have to remove the standard grill, cut the plastic circle on the actual bumper off and then push the honeycomb in quite hard so clips in then put the 4 screws back on from the top.
As he said... had to do the same with a mates car... it seems to be the only way...
