Guess the item
Hey just made these at work took me a while to get the dimensions for the holes but when i finally did i made these on the cnc milling machine at work.
pictures below
Can anyone guess what they are? A clue is they are probably more specific to my polo due to something thats quite unique that I've done to it and a problem that was caused when i did this particular modification.
you can see my car in my build thread which needs alot of updating as a lot has happened since i first started it.
enjoy
165757_1838222195978_1253192899_32039101
166448_1838221715966_1253192899_32039099
Edited by StinkyPete
  • Views 1.3k
Drop plates!
What they made from if so?
20mm thick steel plate bar.
and as you said in my build thread forward plates not drop plates lol. I like it
what does it actually do?
Sorry, j never it those dimensions for you. Slipped my mind even after you Pm'd me to remind you. Sorry again! They look good!
Essentially, for those who asked, they move the wheels further forward and into the middle of the arch. I know the reason for them, but I don't want to give his secret away just yet... :ninja:
Edited by prankstar2003
i'm not conviced by these tbh, they will do the job you want them to do but they are going to be subjected to some massive forces and be stressed in ways that the standard set up isn't. With the hub being off center to the mounting face on the axle any downward force on the wheel will in essence be trying to twist this plate on the mounting face. Will it be enough to cause failure? Who knows but what i would sugest is once this is bolted to the axle get the welder out and weld it to it too. This should take some of the strain of the bolts, it may be strong enough to hold it without but for the sake of ten minutes with the welder i think would be worth it just for peice of mind.
Another thought tho, is this going to over hang off the mounting face? If so that could become a weak point as it isn't getting the suport that mounting face will be giving the rest of the plate. This would also add aditional force to the bolts holding the plate to the axle during cornering.
as said above these are a death trap, and how it will effect the workings of suspension etc it is crazy
and i am more confused as to why?
i think the time spent planning and making these would of been spent more wisely mocking the arches up properly in the first place tbh.
