1983, Black Mk1 Golf
For sale is my mk1 golf. Had this car almost 3 years now, started life as a standard 1.3 driver but since then it has undergone a big block engine change, re spray and many other modifications. It’s a lovely car to drive, handles amazing and pulls really well. But really need a more economical car now due to increasing my commute and fancying a change. Open to px’s on this but must be insurance friendly as I’m only 18, particularly interested in a polo twist. Or for a straight sale £3400.
Engine :
- 1588cc FR engine, complete with twin choke zenith pierburg carburettor compete changed
- New cambelt, tensioner and auxiliary belt
- Full service including new oil 10/40 semi synthetic and engine oil flush, air filter , fuel filter
- New triple tip spark plugs, rotor arm, distributor cap
- mk1 gti ignition coil.
- New fuel lines and vacuum hoses
- Full coolant change
- mk2 16v radiator and fan and thermo switch
- mk2 16v coolant reservoir coolant system water hoses changed as appropriate
- New water pump and thermostat.
- Throttle cable changed choke cable removed
Full big block chassis conversion including welding of offside chassis engine bracket.
- Engine mount changed for big block engine with poly-urethane insert.
-Gearbox mount changes for 020 box with polyurethane insert
-Front and rear gearbox mounts changed for big block engine/ 5 speed gearbox
Transmission and Drive train :
- FD 5 speed mk1 gti gearbox with flywheel and clutch.
- Full 5 speed gear linkage conversion and gearbox linkage conversion
- 90mm gti mk1 driveshafts and gti mk1 hubs with bearings.
- New clutch cable and new speedo cable
Chassis :
- Poly bushed control arms
- gti anti-roll bars fitted with necessary chassis brackets.
-FK Highsport Coilovers
-White Porsche teledials with nearly new toyos
Brakes:
- Audi 90 256mm front calipers and carriers,
- Pagid fast roads brake pads
- Zimmerman 256mm cross drilled front discs.
- Corrado g60 brake servo conversion
- Golf 16v 22mm master cylinder
- New brake fluid
Exhaust :
- 1.6 mk1 manifold , down pipe and full exhaust system changed, new rear silencer.
Exterior:
-Respray in straight black May 2010
-Chrome side and sill trims
-Full chrome window seals
-Rear screen louvre
-Crystal cross hair headlights
Interior:
- Fronts - Rs Turbo Recaros retrimmed in leather and tartan centres
- Rear – Mitsubishi Evo 8 rear benched trimmed to match - still waiting on this, just the last few little touches to be done
- Brand New Newton Commercial Door cards front and rear
Full cobra cat 1 alarm fitted also.
6 months MOT and Tax.
More pictures on request, questions by pm please.
Alex
  • Views 1.2k
Forgot to mention, Sunroof model, wolfsburg steering wheel, 101500 miles and pictures for those who wanted some with the louvre,
Alex
This is crying out for some shiny OZ Turbos!
GLWS :thumbsup:
GLWS :thumbsup:
Thanks and I know they were the wheel of choice, but couldn't afford them when looking for wheels. Might happen if it doesn't sell though. Rear bench will be in by the weekend also.
Alex
9n3 or mk5 golf px plus cash your way
Offers?
