it would appear i have broken my lock
today i was trying to get into the car and the fob was playing up so used the key turned it and there was some resistance so i turned it more aggressively heard a breaking sound sound now my key rotates 180 degrees without doing anything.
is it possible to get replacement barrels that are made to fit my key or has something come loose
ps the driver door lock that i broke never unlocked all doors when i turned the key but it does when i turn it in the passenger door
  • Views 1.7k
Don't quote me, but this is some sort of security feature on Polo's?
I'd have thought (still don't go quoting me) that you'd be able to take door card out, all the rest of the items attached and then have a look at what snapped. Might be a quick job, might not but worth having a look yourself before you pay a mechanic/locksmith.
This might help with getting to the lock itself (so long as you can get into the car from the boot/other side): http://forums.vwvortex.com/showthread.php?1015107
Edited by Liquidice
there is no problem getting in just i cant use the key on the drivers door i was hoping that it would be a loose linkage, when i next have some free time ill have a gander behind the door card thanks for the help
when you said door pin i got confused i was like "my door pin is fine goes up and down a treat" but then i clicked the link and i feel you may be on to spmething there old chap thank you very much i'll delay it until i figure out the door card removing stuff
This happened to My Golf MK3, both locks and I had to climb in through the boot.
It happened when it was cold and the parts inside broke, as in the metal that turns and then activates the central locking broke. You can get the parts from VW pretty cheap and its an easy job to do. It more than likely wont be the actual lock barrel, it will be the linkage inside.
Go to VW dealer, explain what's happened, the parts for a Golf MK3 were about 7 quid.
Good Luck!
yeah sorry meant spade :) i brought this and an actuator and it fixed the problem :)
ok so finally ordered it and hopefully it'll do the job, i'm tired of walking round the passenger side unlocking it the wandering back round to open the door when my fob wont work because its cold.
