converting an early mk3 spec headliner
the polo i drive is a mk3 cl from 1991, and my doner car is a later spec 1993 genesis which has a good headliner in it. Anyone who has an early cl knows the headliners arnt the best and i ended up ripping mine out as it was knackered.
so what i want to know is will the genesis one be easy to fit in mine? the sunroof is different but i can take a notch out of the genesis 1 to fit around my sunroof. is everything else the same? is it on clips or are they glued in?
cheers
  • Views 805
Does your car have a factory steel sliding Sunroof?
Yes = it will pop right in but you will need to take the glass out to do it right. Just push towards the back of the car at the metal rods positions to disconnect from the wee clips
No = unlikely to fit will be slightly short in places. And the mounting points are slightly off as the factory sunroof model roof is double skinned (lower - less material).
ahhh, no its just the pop-up glass sunroof. thanks for that though :thumbsup:
