car PC
anyone fancy a PC for their car ?
£160 delivered
pm me for more details
change of plan
  • Views 478
CARPUTER IN CAR PC VOOM VIA MII M2-ATX MINI ITX
I bought this off eBay last year and didn’t get round to fitting it. I’ve had it running all week and it runs with no problems. It will come with the harness to wire to your car (see pic). I will also supply the via motherboard, m2-atx power supply, manuals (pdf) and drivers which came with it (on CD not original). Centrafuse is the main excellent in car software program already installed (see pic). It is a fast pc and has the following spec:
40gb Hard drive (upgradable)
500mb Ram (upgradable)
1.20GHz Processor
Via EPIA MII 12000 motherboard
M2-ATX power supply
VoomPc enclosure
All the following software is already loaded & ready to use:
Windows XP Professional light service pack 2 (will run Linux)
MS Office 2003
Centrafuse GPS Navigation Bluetooth Handsfree Web Browsers All Media +more
Alcohol 120%
Power DVD
Virtual DJ
+ other usual software
NOT INCLUDED :
Monitor
Keyboard & Mouse
GPS antenna
Bluetooth adapter
You will need to buy a usb GPS antenna to use the sat nav & a usb Bluetooth adapter to use a handsfree phone. Both are sold cheap on eBay. You will also need a touch screen monitor to use the pc in a car.
Here’s some info I found on the web:
VoomPC car PC enclosure
The voomPC automotive (car, boat, electric cart) enclosure is a small, rugged car PC (carputer) enclosure designed to work in harsh environments such as dust and high temperatures. Made our of massive 5.5mm extruded aluminium profile, the voomPC car PC (carputer) enclosure was designed to work with any type of mini-ITX motherboard (170x170mm) from fanless configurations such as VIA mini-ITX or Pentium or low power Pentium-M processors, making it the ideal car PC solution. This car PC / carputer enclosure is specifically designed to work with the M1/M2/M3/M4-ATX car PC automotive power supply series. Your ideal under the seat or trunk car computer.
The VoomPC car PC (carputer) enclosure can take one 2.5" hardrives.
Dimensions : 210(W)x254(L)x56(H)mm
M2-ATX power supply
Power challenges in a Vehicle PC
The 5V Standby Problem: One of most difficult tasks of operating a PC in a vehicle is power consumption while the computer is OFF. Even when your computer is OFF or in Suspend, it will still consume about 50-150mA on the 5VSB rail. No matter how big your battery is, you will eventually drain it if proper actions are not taken. The M2-ATX is addressing these issues by cutting off the 5VSB rail after a pre-defined amount of time (see jumper chart,HARDOFF). When 5VSB is always active (HARDOFF=Never), M2-ATX constantly monitors the battery levels. When battery level drops below 11V for more than one minute, M2-ATX will shut down and re-activate only when the input voltage is > 12V. Engine Cranks, under-voltage and over-voltage situations. Another difficult task is maintaining stable 3.3V, 5V, 12V and -12V power to your PC. While car batteries are rated at 12V, they actually provide voltages in between 7-16V (engine cranks) or as high as 80 volts (load dump). Most of the times, your battery will stay at 13.5V (while car is running) but extra precautions need to take place in order to prevent such situations. M2-ATX can operate as low as 6V and as high as 28V while providing strict regulation on all rails along with input voltage clamping and reverse protection. Loud amplifier pops when PC starts. If your PC is connected to your car amplifier, you will hear a loud pop when the computer
is first started. The M2-ATX has an .anti-thump. control that will keep your amp OFF while the PC starts. Simply connect J6 to your amplifier remote control pins to activate the .anti-thump. feature.
There’s more info on the supplied manual.
EPIA MII-Series Mini-ITX Board
Providing the signature low profile, minimal noise and reduced power of the VIA EPIA series on a 17 by 17cm small form factor, the VIA EPIA MII Mini-ITX Mainboard is an “all-in-one” entertainment platform geared to the digital home. The VIA EPIA MII-Series easily slots in to a digital home infrastructure providing a vast horizon of applications that feature sophisticated connectivity including wired or wireless media servers, mobile PCs, receivers for the living room and beyond.
The VIA EPIA MII is available with the fanless VIA Eden™ ESP processor for ultra low power, quiet or silent system designs, or the VIA C3® processor for rich media-intensive applications. Enhanced multimedia performance is further delivered through the VIA CLE266 chipset featuring integrated VIA UniChrome™ 2D/3D graphics and an MPEG-2 accelerator with motion compensation, along with support for the greater memory bandwidth of DDR266 SDRAM and the high transfer speeds of ATA-133.
An array of modern storage and connectivity options are supported, including onboard CardBus, CompactFlash, and a PCI slot. The VIA EPIA MII also offers support for the latest in high bandwidth connectivity through IEEE 1394, USB 2.0 connections, as well as S-Video and RCA TV-Out (NTSC & PAL) and 10/100 Mbps Fast Ethernet. The VIA EPIA MII also offers support for a number of embedded LCD panels and is fully compatible with Microsoft® Windows® and Linux operating systems. The VIA EPIA MII can be fitted into a full range of Mini-ITX chassis as well as FlexATX and MicroATX enclosures and power supplies.
any offers ?
if it wasnt windows lol
any pictures ? and square size please. thanks
