Breaking In To Your Own Car :(
wedge in the top of the door as stated above, (polo mk?) if manual windows wind down the window with a hook on a strong length of rod, done this before after friend had locked his keys in the car.
mk4 i assume after reading the op again.
if it is a mk4 polo, then jack up the car and you can pull the bonnet cable to open the bonnet, then you can connect the battery.
how is the passenger door openned if delocked? popper or just reach over from drivers side? if you have flush fitting door pulls how do you unlock it from inside? must be some sort of knob to pull up?
There is still a handle but no lock,and i have Remote C/L so when i press the button it all opens and i dont unlock it from the inside as it would already be unlocked for me to get in lol + There is nothing to pull up
  • Replies 33
  • Views 3.4k
you could try bending the top of one of doors back i saw a security guard doing this for a lad at work in the carpak (he wanted to lock up and go home)
it does take alot of brut force but can be risky i suppose, you try heating up the paint to be safe, you dont need to bend it much enuff to open the door or whatever
haha you didn't think it through when removing the battery then eh? :p
Just throw a small kid through a back window, sorted.
i prefer this idea myself but your choice lol
Am i fuck bending the door
x2 haha
i would use a brick way before considering bending the door,getting glass is a lot easier than a perfectly matching door.
tried popin the bonnet manually? I've done it plenty of times on my mates polo's jack it up and shove your hand up there ..
none of this will help as he doesnt have a C/L pump on the car, lol.
Personally i'd've blagged the window by now, or as the lock's fucked anyways, went in that way
I Know are looks like a window job oo well
If the barrel bit on the handle is knackered anyway drill it out so that you see the catch behind and you should be able to get to latch with a screwdriver or something to manualy unlock it if you get what I mean lol
