mk2 dash removal
Right i have got to put my new windscreen in soon within the next two weeks ideally but i want to remove the dash to do this to make it easier and i also think you need to so that you have full access. So does any one have a quick guide or just an explanation of where the main bolt locations are and any clips or anything specific i need to do to get it out please.
Any help would be great.
Please and thanks.
Peter
  • Replies 8
  • Views 3.3k
you dont need to touch the dash to fit a windscreen
true that ^^ I popped the windscreen out at the top first then gently round the sides. Just lifted the bottom out :)
removing the dash and associated wiring, buttons etc is a chore I would avoid if possible
get a haynes manual tells you everything in there would scan mine but cant find the bastard
i also need to take the dash out for other reasons so do need to know how to get it out please guys and i have a haynes manual and have checked and cant find anything for dash removal.
so any help please guys.
have you had a look
I've not done one , but id imagine clocks out , steering wheel off , heater control off , under trays off , screws underneath , some under the scuttle and it should lift out , might be some wires clipped under it
I have had a look and had most of it apart in different bits at times just want to make sure that i undo everything so that i dont forget something and go to force it a little because i think its stuck but its still attached and end up breaking it.
Just want to make sure i get all the big major attachments undone.
Just go for it and take your time. Look in little corners etc to see if a random screw. i thought i saw a section within the haynes manual that says where the screws are.
Theres two 10mm or 13mm nuts under the the hood. take the steering wheel off and the under trays and your pretty much there.
