Dropping my 6n
Now I've had my car back from the body shop after my incident with a 4x4 I've been thking about doing a few mods one of them being lowering from the standard stance , I've being toying over what wheels for a while and decided on going with the G60 steels (15s) but rather than using coilovers its been suggested by the local garage by using lowering springs ,so what I'm asking is what would be the safest drop without it rubbing ?? as ill be dropping it before i get the steelies
  • Views 783
It's hard to say without a little more information. It depends on how stiff your suspension is, what tyre size you have, if your going to space them out at all. My 6n is down just over 100mm and that's on 15 7j at the front and 15 8 j at the rear with no arch work but I have nearly no suspension haha.
Personally I would go with coilovers because then you can just adjust it to the ideal height when you get your wheels :thumbsup:
Try using the search function in the Wheels, Tyres, Suspension and Brakes section. This kind of question comes up all the time.
