New Member and Owner
I have just bought a little MK4 1.4cl (I know nothing too glamorous!) which will ultimately go to my partners son when he is 17 later in the year.
We are both into our cars quite a lot and I have been a memeber on a few forums (206 GTI, MG, RX-8 & Vectra C) in the past and know how great they can be. I have been lurking around for a few months now just watching, but since I have actually purchased the car I though I would register and say hello.
Got the car for £900 so not expecting too much (again as it's going to be a first car), but there are a few things I need a little help with;
- passenger side window goes down fine, but will not go up unless you forcibly push it (electric)
- stereo just does not work, I have played around with the wiring but nothing, its dead as a door nail.
- Clutch seems quite heavy to me and is a little high but I am comparing this to my car which is a little too easy and boring to drive
- both electric mirrors move up and down but not side to side
The car already has a set of 15" Ronal alloys (which are..... :? ) and I've already made some enquires on here about lowering, front badgeless grill, clear indi's and sides.
Any help or assistance with any of the above would be greatly appreciated and I look forward to being a member here...
Edited by Big Crouchy
  • Views 889
I can't imagine Abbey Clancy driving a MK4 Polo..
But my god son, you've done well. She's a fittie. She's bang tidy. Fittie fittie bang bang. :p
Heavy clutch,could just be your skinny lanky legs. Or that its a cable job.
Stereo,you can test the feed is live using a bulb,try the fuse in the stereo,sounds dead.
Windows can go off true horizontal and 'wedge' in the runners,sounds like worn or broken part that holds the glass,get the door trim off and have a look - or get your butler do it. :thumbs:
HaHa....Knew the Crouch jokes would be on the cards pretty quick!! Being 6'5" and actually looking like the big man means that I'm used to it!
When the weather picks up I'm going to strip a few things down and have a proper look.
Another quick one, the alloys I've got are 15's but when I hard lock to the left there is some scrub coming from the near side wheel arch, but its not replicated if hard locked the other way...I've poked my head around but cant see anything obvious. Obviously a sIm looking to lower I am slightly concerned...
its all depends on the widths of the wheels mate, i would maybe go for slightly slimmer wheels if i were to lower (assuming the wheels are really wide?). nice to see someone else from sussex on here where abouts are you?
Edited by leonh
As above its not necessarily the width but the offset of the wheel, which is basically whether the bolt mounting face is closer to the 'front' or back of the wheel, and as such affects how close it sits to the arch. If you had a 15x7 et0 this would mean the bolt face is exactly in the centre of the width of the rim i think, but i don't know mk4's very well... If you spend some time looking through build threads you can see what wheel size and offset different people have, and how it sits in relation to the arch. This will enable you to swap the rims for something more exciting whilst running it fairly low.
One trick is to bang the inner arch lip flat so it doesnt touch the wheel, or you could get the arches rolled/pulled if this doesnt sort it? Or just run it on 13x8's and get coilovers so it sits on the floor. But not massively practical! Hth.
