clutch adjusment polo 6n2
how do you adjust the hydraulic clutch cable to make it lower/higher biting point etc, could someone describe how to do it like, turn the nut to the left etc or direct me to a thread or topic if one exists, cant find any
:-D
  • Views 6.9k
Not sure if there's a thread or not I didn't have a look :p but it's pretty simple. The cable runs from the firewall to on top of the gearbox, and it's slotted in two brackets, and on the end are two nuts, one adjustment (10mm?) and one locking(8mm?). Just undo the first (locking) and then tighten the second to raise the bite or undo to lower... I think, you should check as you do it though :p
Pretty simple though! In the Haynes I'm pretty sure it says leave about 1cm as a rough guide of movement on the peddle before it reaches it's resting point.
Hope that helps! It really is that simple to do!
Edited by loudervision
nice one pal, thanks a lot :biggrin:
No problemo ;) hope it goes well!
:-D
hydraulic clutch cable !!?? i've been off the spanners for a while now but never seen or heard of one of these
not the cable sorry, the clutch
