Forte formula
Right for sale i have these engine and fuel treatments, i have a couple of each but i am selling them individualy but can do a deal if you want more than one.(400ml bottle)
Forte Diesel treatment:
-Reduces noxious exhaust emissions
-Improves engine performance and driveability
-Improves cold starting
-Prevents fuel system corrosion
-Lubricates and extends the life of injectors and fuel pumps
-Controls fuel oxidation and gum, varnish and acid formation
-Reduces valve, combustion chamber and EGR valve deposits
-Restores injector spray pattern
-Compatible with catalic convertors and particulate traps
-DOES NOT RAISE CETANE RATING
Just simply pour into fuel tank and drive away.
Forte Gas Treatment: (for petrol cars, only for spark egnition)
-Reduces noxious exhaust emmisions
-Provides injector and upper cylinder lubrication
-Frees sticking compression rings
-Reduces valve and combustion chamber deposits
-Maintains EGR valve and oxygen sensor cleanliness
-Compatible with catalic convertors and oxygen sensors
Forte Motor flush:
-Cleans engines internally and provides anti-wear protection
-Neutralises crankcase acids
-Removes lacquer, varnish, sludge and insoluble deposits from the crankcase
-Frees sticking variable valve timing systems, hydraulic valve lifters and piston rings
-Stabilises cylinder compression restoring lost engine power
-Cleans oilways ensuring oil flow to critical moving parts
-Keeps new oil cleaner for longer
Just simply pour this into the engine before an oil change, leave running for about 20-30 mins, swith engine off and drain oil! Simple
RRP £18 But i am selling it £13 posted, will be able to do a deal if you want more than one, just let me know
  • Views 202
Popular Days
anyone?
