Polishing cloths?
I've just painted my carbon bonnet, and then wet flatted the top coat to take a few bits of dirt/dust out.
I've given it a once over with G3 but i think the polishing cloth i'm using keeps putting scratches into the surface.
I know you can buy these microfibre cloths but would this solve the problem?
  • Replies 9
  • Views 1.2k
most 'polishing cloths' iv used you can watch add swirls, - dont have this with GOOD microfibres but cheap ones have the same effect
how do you tell a good one from a cheap one? just buy a decent 3M branded one or something?
i used to find the same problem as you after flattening and polishing but found out the solution
first i bought a super plush micro fibre cloth fro the ultimate finish
oh and in-between these steps do not wipe the bonnet with the micro fibre cloth till its finished
what to do it polish up your bonnet using your G3 (i find G6 rapid does a much better job)
once polished apply the yellow polishing head to the polisher and apply some 3M Perfectit II and work it into the bonnet
Now apply the blue polishing head to the polisher and apply some 3M Ultrafina II, work it into the panel then apply 1 more coat
leave five minutes before touching the bonnet with the micro fibre
it takes a bit longer but in the end i always find the finish is far far better and you don't find any swirls under the halogen lights and no fine scratches
Hope that helps
Jordan
good advice, but the bonnet is carbon - i can't use a porter cable mopping system on it, i have to do it by hand if i use a porter cable the heat generated may possibly damage the top gel coat of the bonnet, especially if theres any small air bubbles which will expand and crack the top surface!
trouble is, when your polish/wax dries, it can clog in the cloth and because its sightly abrasive you almost drag it around causing slight marks, just try using a few decent clothes and always turning them to a clean bit?
well i think i'll try some megs scratch x on a proper applicator and a clean microfibre to take it off. The finish of the paint is really good, it's just a bit hazy and the haze is all the direction it's been polished in so i think its partly the cloth thats been used.
it doesn't matter if its carbon i've done it with an impreza carbon bonnet and it comes up perfect
scratch x is quite rough, try something milder?
it's really quite hazy, i have tried a lighter surface prep and it hasn't even touched it.
regardless of it being carbon, i'm not risking it as its a complete one off.
