Removing window switch from housing?
Can anyone guide me please?
  • Views 832
Popular Days
Once you've got the switch in your hand?
If you flip it over, there is 6? plastic tabs on the bottom of the switch (where the connector is). It's either 6 or 4? Lever 2 outwards, only slightly, and prise the bottom of the switch up..
The switch should disassemble after a little persuasion. :) Assuming you're cleaning the contacts, watch when you finally get the bottom off, the little metal push buttons like to go walkies.
