carbon fiber sticker mods ?
I'm interested to see what some people have done with those carbon fiber sheets to their interior/exterior ?
The dash on my 6N is getting all cracked and old, and I thought to put a huge Carbon Fiber sticker on it from ebay. Black.
Do you think it would stick well and look sharp ?
How much Carbon fiber will I need to coat the dashboard ?
Also, anyone have a guide on changing the roof light bulb to a blue one ?
Edited by MK3Dawg
  • Views 1.2k
What do you mean by carbon fibre sheets? You on about the cheap 3m backed vinyl stuff or? Will look alright but has abit of a tendancy to start peeling, especially if it get warm but if you really dont like the look of your dash then give it a go...You'd probably get a better result just prepping the area nicely then spraying it in my opinion...
...And changing the roof light bulb??...if its as easy as on a 6n then surely you can manage that?...just pop the light and surround out of the roof lining, unclip the wire (don't have to unclip it but does make it easier and only takes 2 seconds) then remove the bulb...if its the same as a 6n its just held by a tensioned metal strip and then change for a blue bulb...I'd recommend getting a 6 or 8 l.e.d bulb if you want it nice and bright...hope this helps.
Thanks ! Could you give me an ebay link to a bulb that will fit and br bright ?
I'm not sure what the size the bulb is on a mk3, best bet is to just get it out and check before buying...and any l.e.d set-up should be pretty bright...i'm using an 8 l.e.d bulb in mine and its more than bright enough... ebay your looking at a couple of quid max.
Oh I'm using a MK4 6N ! Is this what I need ?
http://cgi.ebay.com/ebaymotors/2pcs-39mm-B...sQ5fAccessories
Can I pull out the plastic button without pulling out the roof ? Just pry it out with a screwdriver ?
Edited by MK3Dawg
What kind of bulb would be best for a 6N then?
