any ideas for hinge pin swappage
i need to bash that hinge pin out due to wear n tear , I've done top ones before where you get at them and they're super tight
needs to go from left to right as the picture shows it , as you can see no room to get a punch at it really
all i can think off is drill a sturdy bit of angle iron and plug weld onto the pin and hope it holds while i batter it one
any ideas folks
  • Views 660
Popular Days
i would try cleaning it up a little better remove paint from ends of pins then soak with wd40 then hit the pin wrong way in towards the car to losen it up then back out as for getting it out once moving you are not gunna be able to chase it down the hole because of the angle you are on so mole grips on the end of the pin and twist whilst pulling it out.
failing that just cut hing off get pin out swap an weld bk in bit of white paint.
