Can you raise car height without changing springs?
Dudes, mate of mine needed some advice, he's slammed his car too much and now he can't use it in most areas CID of bumps etc. problem is stock springs are very hard to get hold of so is there a method of raising car height? Was told by someone you can get a set of blocks, anyone heard or used? Ta
  • Replies 26
  • Views 3.5k
usually suspension thats 'slammable' is adjustable? if not then he'll probably have to buy OEM shocks and springs from a factors.
wel how did he slam it?
LOL sorry this just made me laugh,
£5 says the springs have been cut :lol:
£5 that they try to stick Concrete Bricks at the bottom of the spring to give it height!
(joking <3 x)
Edited by LOGiCALX
whats the make and model?
tbh unless its rare or very old, springs are not that hard to come by.
go to scrappers pick up standard springs, done
Right well firstly the two betters amongst us have both won £5 each! lol Yes they have been cut but mainly due to the scarcity of the springs.
It's a 280zx, and it's mine.. there is no friend :?
check American ebay but postage is not cheap.
Man up and watch for bumps
Cutting springs = FAIL
Best thing you can do is go to a breakers and just buy a set of stock springs
Or you should have done it right the 1st time and use'd Springs and Shocks Or Coilovers 8-)
Edited by Po*Low*
there's nothing wrong with cutting springs if it's done correctly it will have no effect on the safety of the car or the longevity of the spring.
eh? :?
scrappies and ebay? can you not get them from the manufacturer?
Ah it all makes sense now.......
I bet they were discontinued a long time ago...
Well, in my mind there's two options. Order a set from the USA and pay a shit load for postage and import tax.
Or, find out the coil diameter, length, no. of coils and spring rate; then try find some springs that fit the bill from a more common car. (Possibly a 300zx?)
I've cut springs on tonnes of cars and know people that do it everyday, never heard of any adverse effects.
What are these blocks I've heard of then?
Oh dear,someone's got carried away and chopped off too many coils..
Leda will make you a new set. They'll make them to your preference,too. Send em an email (cant remember the address you'll have to google,but its like sales@leda.co.uk).
Should be about £65 per corner.
Dont use these!
these are what i think you're on about, you will regret using them.
lol, there ok for the use advertised for, but not permanently.
Yeah, i agree with you there mate
I can't afford new springs! Not bothered about ride quality, have you used them halford ones mate to advise against them?
Link 1
Link 2 (ebay)
Check these out and make sure to half the price to get it in sterling GBP.
I've experienced them yeah. Ride quality is shocking, like bone crushing bad.
But the main problem is that because you're only stiffening up the section of the spring you put the rubber in the rest of the spring is left with alot more strain then it's used to taking and it will slowly but surely cause the spring to become naturally more compressed and so you'll be back to square one.
tbh your only option is to fit them and save up for new springs asap as they will affect the handling and therefore the safety of your car.
jack it up and jam blocks on rubber or wood in the gaps between the springs...................
might stiffin the ride to :lol:
