Matt colour spraying
Hi I'm about to respray my interior door handles matt black(all preped good) but what i want to know is if i put a laquer on the matt colour will it lose its matt effect? Ill need to protect the colour as it will just peel from just paint wont it?
If i shouldnt use laquer what should i use as a protection?
  • Views 1.3k
you dont need to use anything to protect it. Especially on the inside of the car.
The only reason for peeling would be crap preparation.
as long as the surface is prepared and adequate time is allowed for drying it should not flake or peel etc .. but if you wanted to use a laq' just get a matt laq'
matt lacquer will help keep the paint sealed and make it easer to clean any peeling will be due to poor prep or incorrect priming.
Can i use standard primer or should i use plastic primer? Also matt laquer where can u find this? I can only find clear laquer, id prefer to seal it as everyones hands r constantly gna b on it as its the handle part
if its plastic i guess a plastic primer , I'm sure mikeymk recommends an acrylic based paint for plastics , and as for a matt laq' loadsa places sell it ,, art shops . halfords will I'm sure ,
^^ I think you're partially remembering me saying i had bad results with plastic primer and acrylic paint,and went on to have success with vinyl paint instead.
That was on the exterior though. Id avoid painting interior handles even in vinyl tbh,and just fit black ones instead providing they're available.
