I'm not sure what this is called?
Ok, so my wheel has been rubbing in the arch (only on the drivers side) and only under braking
i can see that the driver one of these is bent like a banana. i think that's the start of fixing it.
also i think i need a new suspension strut to straighten the wheel in the arch (like the pasanger one)
any ideas?
cheers
  • Views 515
tie rod, or steering arm.
that arm has a removable ball joint end, which is replacable, or the whole arm can be replaced.
cheap from GSF
FYI, the drivers arm is bent from factory
Edited by grungeisdead
nice one mate, i'll have a look at some pics in comparison to mine and work out how bent?
