will these fit my 6n?
Pct is 100x4 or diagonally 100mm furthest and 70mm closest. Rim is 13x6.5
and bolt size between 15 and 16mm
Just wondered before I commit to buy them
Thanks guys
  • Replies 13
  • Views 1.4k
i wood say no.. the distance betwean wheel bolts shoud be 100mm not 100mm diagonally
Edited by 13kpologt
Ahhh nice one mate cheers, shame the wheels look really smart.
A four stud wheel is measured diagonally for a PCD, so measuring from opposite bolt holes should be 100mm.
Hope this helps.
Pete.
They came off of a triumph spitfire if that confirms them not fitting???
spitfires were 4x4'' i think
meaning your metric PCD is 4x101.6, so youll need wobble bolts and spigot rings if the centre bore isnt 57.1 :D
Yeah that's what I was kinda hoping, I was thinking along the lines of wobbley bolts and they would fit?
Sorry for sounding a bit of a noob guys I'm normally use to buying wheels I no will fit but these are a bit special.
Yeah i'm pretty sure wobble bolts will fit 101.6's
and you'll have to measure the centre bore to get the right size spigots!
Well I've been searching google like mad and I'm still no cleared if they will fit?
Arghhhhhhhh lol
Spitfire, GT6, Herald, Vitesse, Dolomite, TR7 all have 3 3/4" (95.25mm) P.C.D. If this helps any one in lighten me. I no woonleys work on 101.6 but 95.25 won't as far as I'm aware.
You're right bud, 95.25 is a bit far, sorry for telling you they were 4x4, i was certain of it :(
No worries mate I've had so many people say yes and no lol.
My boss use to work for leyland back in the day and he thinks they will fit a mini so should fit with wobbleys but I just dunno. I reckon I should just hold out for some mini lites but these wheels are really different and haven't seen another polo on them. Oh well cheers for the reply buddie
Wobble bolts are only good for about 2mm of variation, hence why they work for 101.6 PCD wheels.. if the wheels you want to fit are 95.23 then they're not going on without a weld and re-drill dude.
I no mate best wait for some different rim's me thinks
